Zum Hauptinhalt wechseln
2012-2015 Honda Civic Door Speaker Replacement
Englisch
Deutsch
Schritt 7
2012-2015 Honda Civic Door Speaker Replacement: Schritt 0, Bild 1 von 1
  • Remove the one 25 mm Phillips head screw/8mm bolt holding the speaker in place with either the #1 Phillips screwdriver or an 8 mm socket.
  • With nothing holding the speaker to the door, pry the speaker away from the door with a trim tool.
  • The speaker mount in your car may appear different than in the photos as this is an aftermarket speaker and adapter mount pictured.
  • Once the speaker is out of the door, you will need to disconnect the clip on the wire in the rear (similar to the window control on the arm rest.)
  • Not pictured, you are going to want to mount your speaker to the adapter that comes with your aftermarket speakers and set aside. Your speaker or adapter should have instructions on how to do this.
Hier Übersetzung einfügen
