Zum Hauptinhalt wechseln
HP Compaq Pro 6300 RAM Replacement
Englisch
Koreanisch
Schritt 3
HP Compaq Pro 6300 RAM Replacement: Schritt 0, Bild 1 von 3 HP Compaq Pro 6300 RAM Replacement: Schritt 0, Bild 2 von 3 HP Compaq Pro 6300 RAM Replacement: Schritt 0, Bild 3 von 3
  • Put your thumbs on the two tabs surrounding the RAM sticks and push down.
  • This requires a lot of pressure, so don't be afraid to give it some force.
  • If you need more room, you can unplug the SATA cables that connect the hard drive and DVD drive to the computer- just make sure you plug them back in when you finish.
  • Pull the module out by the top or the sides. Take care not to touch the delicate pins at the bottom and the chips on the surface.
  • You may have a different number of modules depending on your configuration. If you have one or more empty slot, you can skip to step 4.
Hier Übersetzung einfügen
