Zum Hauptinhalt wechseln
Carrier 14 Seer Heat Pump Capacitor Replacement
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Carrier 14 Seer Heat Pump Capacitor Replacement: Schritt 0, Bild 1 von 3 Carrier 14 Seer Heat Pump Capacitor Replacement: Schritt 0, Bild 2 von 3 Carrier 14 Seer Heat Pump Capacitor Replacement: Schritt 0, Bild 3 von 3
  • Caution: Use a non-contact voltage tester or a multimeter to make sure that the breaker is not electrically charged. If you do not have access to a multimeter, tap the breaker box with the back of your hand. If you use the palm of your hand and there is a charge, your hand will clench, making it hard to remove your hand from the box.
  • Turn off your heat pump unit's breaker.
Hier Übersetzung einfügen
