Zum Hauptinhalt wechseln
How to Apply Liquid Metal in a PlayStation 5
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: Schritt 0, Bild 1 von 3 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: Schritt 0, Bild 2 von 3 How to Apply Liquid Metal in a PlayStation 5, Remove the old liquid metal from the heatsink: Schritt 0, Bild 3 von 3
  • Wear gloves to protect your skin from the liquid metal.
  • If you have a disposable syringe, you can use it to suck up any large pools of liquid metal. Don't use the syringe containing your new liquid metal.
  • Starting with the heatsink: apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to a cotton swab and carefully clean up all of the liquid metal from the heatsink surface.
  • Removing the liquid metal can be tricky—it spreads and smears easily. Switch to new cotton swabs and apply more alcohol as necessary.
  • Use the same cleaning process to thoroughly clean up all of the liquid metal residue.
  • The surface needs to be completely clean for the new liquid metal to work properly.
  • Let the heatsink dry completely.
Hier Übersetzung einfügen
