Zum Hauptinhalt wechseln
Cricut Maker 3 Belt Replacement
Englisch
Koreanisch
Schritt 25
Cricut Maker 3 Belt Replacement: Schritt 0, Bild 1 von 3 Cricut Maker 3 Belt Replacement: Schritt 0, Bild 2 von 3 Cricut Maker 3 Belt Replacement: Schritt 0, Bild 3 von 3
  • The gear you remove in this step has a small cap at its bottom that will fall off when you slide the gear out of the bracket. Be careful not to lose it.
  • With one hand holding the motor, use your other hand to remove the gear from the motor bracket.
  • This part can be tricky. Adjust the motor and pull the gear at different angles until it comes free.
  • As the gear comes free of the bracket, lift the gear out of the belt.
  • During reassembly:
  • Thread the belt through the opening in the motor bracket.
  • Insert the smaller part of the gear into the belt and replace the cap on the bottom of the gear.
  • Hold the gear, belt, and cap in place as you place the gear into the motor bracket.
Hier Übersetzung einfügen
