Zum Hauptinhalt wechseln
Mayflash Arcade Stick F300 USB Cable Replacement
Englisch
Deutsch
Schritt 2
Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 0, Bild 1 von 3 Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 0, Bild 2 von 3 Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 0, Bild 3 von 3
  • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
  • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
  • Use a metal spudger to gently remove the softened glue.
  • Remove the cable from the socket
Hier Übersetzung einfügen
