Zum Hauptinhalt wechseln
Casio CZ-1000 Power Switch Replacement
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Casio CZ-1000 Power Switch Replacement: Schritt 0, Bild 1 von 3 Casio CZ-1000 Power Switch Replacement: Schritt 0, Bild 2 von 3 Casio CZ-1000 Power Switch Replacement: Schritt 0, Bild 3 von 3
  • Heat the soldering iron and use a desoldering braid or pump to remove the solder from the pins of the old switch.
  • Once the solder is removed, gently pull the old switch out of its place.
  • If the replacement switch doesn’t have pre-attached leads, you’ll need to solder wires to it. If it has leads, align them with the matching holes on the PCB where the old switch was connected.
  • Position the new switch in place, ensuring the leads align correctly with the pads on the PCB. Solder the leads securely, using just enough solder to create a strong connection without any excess that might cause shorts.
Hier Übersetzung einfügen
