Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Schritt 1 übersetzen
Schritt 1
Unfasten the MagSafe port
Use a 2IP Torx Plus driver to loosen (don't remove) the two MagSafe Port set screws a few turns above the frame.
Use your 5IP Torx Plus driver to remove the two 2.7 mm-long screws securing the MagSafe port.
[title] Unfasten the MagSafe port | |
[* red] Use a 2IP Torx Plus driver to ***loosen*** (don't remove) the two MagSafe Port set screws a few turns above the frame. | |
- | [* icon_note] |
- | [* orange] Use your |
+ | [* icon_note] These screws can strip easily. Make sure to apply constant, downward force to prevent stripping. |
+ | [* orange] Use your 5IP Torx Plus driver to remove the two 2.7 mm-long screws securing the MagSafe port. |
[* icon_note] These screws are not magnetic—be careful not to lose them. |
