Zum Hauptinhalt wechseln
iPhone 5s 전면 패널 어셈블리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 32 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 12
iPhone 5s Front Panel Assembly Replacement, Disconnecting the home button cable connector: Schritt 0, Bild 1 von 2 iPhone 5s Front Panel Assembly Replacement, Disconnecting the home button cable connector: Schritt 0, Bild 2 von 2
  • Use the tip of a spudger to pry the home button cable connector up out of its socket.
  • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
Spudger/스퍼저의 뾰족한 끝을 사용하여 홈 버트 케이블 커넥터를 소켓에서 들어 올리세요.
소켓 전체는 들어 올리지 말고 케이블 커넥터만 소켓에서 들어올리세요. 소켓은 자체의 접착 케이블 위에 붙어있어서 조심하지 않으면 떨어질 수 있습니다.
