Zum Hauptinhalt wechseln
아이폰 5s 로직 보드 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 10 übersetzen
Schritt 10
iPhone 5s Logic Board Replacement: Schritt 0, Bild 1 von 3 iPhone 5s Logic Board Replacement: Schritt 0, Bild 2 von 3 iPhone 5s Logic Board Replacement: Schritt 0, Bild 3 von 3
  • At this point, a small metal plate near the rear facing camera is loose and may come free from its recess.
  • Because it is very small and easy to lose, it's best to remove this plate and set it aside while you continue to work on your phone.
  • Use tweezers to remove the plate from beneath the bracket to the left of the rear-facing camera.
  • When reassembling, orient the plate with the small tab to the right and the longest flat edge against the top of the phone.
이 지점에서, 후면 카메라 근처의 작은 금속판이 느슨해져 홈에서 빠져나올 수 있습니다.
이 금속판은 매우 작기때문에 쉽게 잃어버릴 수 있습니다. 휴대폰에 작업하는 동안 이 금속판을 따로 분리하여 보관하는 것이 좋습니다.
핀셋를 이용하여 후면 카메라 왼편의 브래킷 아래에서 금속판을 분리하세요.
재조립할 때 작은 탭이 오른쪽으로 향하고 가장 긴 평평한 가장자리가 휴대폰 상단에 닿도록 플레이트의 방향을 맞춥니다.
[* black] At this point, a small metal plate near the rear facing camera is loose and may come free from its recess.
[* icon_note] Because it is very small and easy to lose, it's best to remove this plate and set it aside while you continue to work on your phone.
-[* black] Use tweezers to remove the plate from beneath the bracket to the left of the rear-facing camera.
+[* black] Use [product|IF145-020|tweezers] to remove the plate from beneath the bracket to the left of the rear-facing camera.
[* icon_reminder] When reassembling, orient the plate with the small tab to the right and the longest flat edge against the top of the phone.
