Zum Hauptinhalt wechseln
아이폰 5s 배터리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 7
iPhone 5s Battery Replacement: Schritt 0, Bild 1 von 1
  • Flip the iPhone back over and insert a plastic card between the case side of the battery and the rear case.
  • Be careful to keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
  • Press the card in farther to break up the adhesive behind the battery.
iPhone을 다시 뒤집고 배터리 케이스 쪽과 후면 케이스 사이에 플라스틱 카드를 끼우세요.
배터리가 구부러져 손상되거나 위험한 화학 물질이 방출될 수 있으므로 카드를 최대한 평평하게 유지하세요.
카드를 더 밀어 넣어 배터리 뒤의 접착제를 제거하세요.
-[* black] Flip the iPhone back over and insert a plastic card between the case side of the battery and the rear case.
+[* black] Flip the iPhone back over and insert a [product|IF145-101|plastic card] between the case side of the battery and the rear case.
[* icon_caution] Be careful to keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
[* black] Press the card in farther to break up the adhesive behind the battery.
