Zum Hauptinhalt wechseln
Mercedes W123 Diesel Pre-Purchase Inspection
Englisch
Koreanisch
Schritt 14
Mercedes W123 Diesel Pre-Purchase Inspection: Schritt 0, Bild 1 von 2 Mercedes W123 Diesel Pre-Purchase Inspection: Schritt 0, Bild 2 von 2
  • Check for ease of movement of all of the vent pods in the dash. They should move easily. Turn the knob to see if they open and close properly.
  • Move the combination switch up and down, for right and left turn signals respectively, and then push it away from you for high-beams. It should firmly move in to each position and stay there without any slop. Then pull it towards you for high-beam flash; it should spring back to the center position when you let it go.
  • Press the center pad on the steering wheel to test the horn.
Hier Übersetzung einfügen
