Zum Hauptinhalt wechseln
Disassembling Motorola i265 Logic Board
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
Disassembling Motorola i265 Logic Board: Schritt 0, Bild 1 von 3 Disassembling Motorola i265 Logic Board: Schritt 0, Bild 2 von 3 Disassembling Motorola i265 Logic Board: Schritt 0, Bild 3 von 3
  • Carefully separate the two sides of the casing by pulling each side apart as if opening a book. Do not be alarmed if the rubber volume control button falls out of the casing.
  • Lay the sides of the phone so they are open side up.
  • On the side of the phone with the logic board, locate the screw as indicated.
  • Use the T-6 screwdriver to remove the screw from this part of the board.
  • Note: Take special care not to lose the white washer that seperates the screw from the logic board.
Hier Übersetzung einfügen
