Zum Hauptinhalt wechseln
Gateway SA1 Outer Casing Replacement
Englisch
Deutsch
Schritt 6
Gateway SA1 Outer Casing Replacement: Schritt 0, Bild 1 von 3 Gateway SA1 Outer Casing Replacement: Schritt 0, Bild 2 von 3 Gateway SA1 Outer Casing Replacement: Schritt 0, Bild 3 von 3
  • Carefully lift the keyboard off from the laptop. It is still attached as shown.
  • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
  • The brown colored component with the tabs does not come out with the connector.
Hier Übersetzung einfügen
