Zum Hauptinhalt wechseln
Mercedes W123 Thermostat Housing Gasket, Diesel Replacement
Englisch
Koreanisch
Schritt 7
Mercedes W123 Thermostat Housing Gasket, Diesel Replacement: Schritt 0, Bild 1 von 1
  • After the two long 13mm bolts are removed the first item that comes out is the bracket that attaches to the A/C line.
  • Note its orientation as you remove it and set it aside.
  • With the two radiator hoses disconnected and the hose clamp on the short lower hose loosened the thermostat housing should pull off the cylinder head and out of the car. If necessary use a small pry tool to gently pry it away from the cylinder head.
Hier Übersetzung einfügen
