Zum Hauptinhalt wechseln
Erkennen und Trennen von Kabelverbindern
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Recognizing & Disconnecting Cable Connectors, ZIF Connectors: Schritt 0, Bild 1 von 3 Recognizing & Disconnecting Cable Connectors, ZIF Connectors: Schritt 0, Bild 2 von 3 Recognizing & Disconnecting Cable Connectors, ZIF Connectors: Schritt 0, Bild 3 von 3
ZIF Connectors
  • Zero insertion force (ZIF) connectors are often used to secure delicate ribbon cables of many sizes. A hinged locking flap runs across the top of the socket, and the cable is inserted on one of the long edges.
  • To disconnect the cable, use a spudger, opening tool, or a clean fingernail to flip up the locking flap—this is the unlocked position.
  • Use the widest tool possible to avoid damaging the delicate hinge pins.
  • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket.
  • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
  • Some cables may have small "arms" or notches that help secure them. If this is the case, you'll need to lift the cable to free it and then pull it out.
  • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  • Some cables (like the one pictured) may have a line that marks the edge of the connection area. Make sure you insert the cable so the line is flush with the edge of the socket.
Zero Insertion Force-Steckverbinder (ZIF) oder Nullkraftsockel werden oft verwendet, um empfindliche Flachbandkabel aller Größen sicher zu verbinden. Über der Oberseite des Verbinders ist ein scharnierartiger Sicherungsbügel angebracht. Das Kabel wird an der breiten Seite eingeschoben.
Um das Kabel herauszuholen, musst du den Sicherungsbügel mit einem Spudger, einem Öffnungswerkzeug oder deinem Fingernagel hochklappen. Das ist die Öffnungsposition.
Benutze ein möglichst breites Werkzeug, damit die Kontakte nicht beschädigt werden.
Wenn der Sicherungsbügel hochgeklappt ist, ziehe das Kabel mit einer Pinzette oder deinen Fingern vorsichtig aus dem Anschluss heraus.
Falls am Kabel eine Zuglasche angebracht ist, dann fasse dort an. Das Kabel kann beschädigt werden, wenn du es direkt greifst.
Manche Kabel sind mit "kleinen Ausbuchtungen" oder Kerben ausgestattet, mit denen sie zusätzlich gesichert sind. Wenn ein solches Kabel vorliegt, musst du erst das Kabel hochheben, um sie zu lösen, bevor du es herausziehen kannst.
Um das Kabel anzuschließen, klappe den Sicherungsbügel hoch und schiebe das Kabel vorsichtig ein. Klappe ihn dann herunter, damit das Kabel fest sitzt. Das Kabel sollte mit ganz wenig Kraftaufwand in den Anschluss hineingleiten. Wenn es schwer geht, hole es heraus und kontrolliere, ob der Sicherungsbügel offen ist. Versuche es dann nochmals.
Bei manchen Kabeln (wie am hier gezeigten) markiert eine weiße Linie das Ende der Kontaktzone. Achte darauf, dass das Kabel so weit eingeschoben ist, dass die Kante des Anschlusses mit der Linie abschließt.
