Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 9
Recognizing & Disconnecting Cable Connectors, Sliding Connectors: Schritt 0, Bild 1 von 3 Recognizing & Disconnecting Cable Connectors, Sliding Connectors: Schritt 0, Bild 2 von 3 Recognizing & Disconnecting Cable Connectors, Sliding Connectors: Schritt 0, Bild 3 von 3
Sliding Connectors
  • Some connectors slide into the side or top of their sockets and have no convenient place to pry or pull. Typically, these connectors have multiple cables attached and are used for small batteries or speakers.
  • To disconnect, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
  • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
  • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
  • Don't push on the cables themselves, or you may damage the connector.
  • Some connectors (like the one pictured) have a small marking that shows which side of the connector should be facing up.
어떤 커넥터는 케이블을 풀기 전에 약간의 달램을 필요로 합니다. 이 작은 iSight 카메라 케이블 커넥터는 들어올 리거나 당길 수 있는 마땅한 자리가 없습니다.
이 시점에서 어떤 사람들은 분리를 포기하고 케이블을 그냥 잡아 당깁니다—케이블이 분리되기는 하겠지만 또한 손상될 수 있습니다.
안전하게 분리하려면 spudger/스퍼저의 끝을 사용하여 커넥터의 각면을 조심히 밀어주세요.
이쪽 저쪽 번갈아 가며 밀어서 커넥터를 소켓에서 살살 "걸어” 나오게 하세요.
[title] Sliding Connectors
-[* black] Some connectors require a little coaxing before they’ll give up their cables. This tiny iSight camera cable connector has no convenient place to pry or pull.
- [* icon_caution] At this point, some people give up and simply pull on the cable itself—which may work, but may also damage the cable.
-[* black] To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
-[* black] Alternating from one side to the other, gently “walk” the connector out of its socket.
+[* icon_note] Some connectors slide into the side or top of their sockets and have no convenient place to pry or pull. Typically, these connectors have multiple cables attached and are used for small batteries or speakers.
+[* black] To disconnect, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
+ [* icon_note] It may take a lot of alternating before the connector comes out. Be patient, and ***don't pull on the cables***.
+[* icon_reminder] To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
+ [* icon_caution] Don't push on the cables themselves, or you may damage the connector.
+ [* icon_note] Some connectors (like the one pictured) have a [link|https://guide-images.cdn.ifixit.com/igi/vxic2PfJnEIjXNSM.full|small marking|new_window=true] that shows which side of the connector should be facing up.
