Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese beinhalten.
Schritt 2 übersetzen
Schritt 2
Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
Repeat this step with the other adhesive strip and remove it.
- | [* icon_note] If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. |
+ | [* icon_caution] Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). |
+ | [* black] Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it. |
+ | [* black] Repeat this step with the other adhesive strip and remove it. |
+ | [* icon_note] If either adhesive strip breaks before it's removed, use a [product|IF145-101|plastic card] to slice through the remaining adhesive. |
