Zum Hauptinhalt wechseln
iMac Intel 21,5" EMC 2805 Display austauschen
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 2
iMac Intel 21.5" EMC 2805 Display Replacement: Schritt 0, Bild 1 von 3 iMac Intel 21.5" EMC 2805 Display Replacement: Schritt 0, Bild 2 von 3 iMac Intel 21.5" EMC 2805 Display Replacement: Schritt 0, Bild 3 von 3
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
  • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
  • Repeat this step with the other adhesive strip and remove it.
  • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
Wenn nötig, kann eine Plastikkarte helfen, den unteren Klebestreifen vollständig zu abzutrennen.
-[* icon_note] If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
+[* icon_caution] Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
+[* black] Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
+[* black] Repeat this step with the other adhesive strip and remove it.
+[* icon_note] If either adhesive strip breaks before it's removed, use a [product|IF145-101|plastic card] to slice through the remaining adhesive.
