Zum Hauptinhalt wechseln
iPad Air LTE LCD Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 3
iPad Air LTE LCD Replacement: Schritt 0, Bild 1 von 3 iPad Air LTE LCD Replacement: Schritt 0, Bild 2 von 3 iPad Air LTE LCD Replacement: Schritt 0, Bild 3 von 3
  • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
  • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Be gentle and keep an eye on the LCD cables as you flip the display over.
  • Lay the LCD on its face to allow access to the display cables.
  • Set the LCD down on a soft, clean, lint-free surface.
Hier Übersetzung einfügen
