Zum Hauptinhalt wechseln
Repairing MacBook Air 2011 A1370 On/Off switch
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Repairing MacBook Air 2011 A1370 On/Off switch: Schritt 0, Bild 1 von 3 Repairing MacBook Air 2011 A1370 On/Off switch: Schritt 0, Bild 2 von 3 Repairing MacBook Air 2011 A1370 On/Off switch: Schritt 0, Bild 3 von 3
  • Got a small aluminum piece from a used Mac battery A1175
  • Grind both upper and lower side off the piece so it fit just against the right wall off MacBook
  • Drilled Ø 4 mm (better measure your own piece) and glued with cyanoacrylate the very far of the small metal tab.
  • Get a push-button small enough to fit below the mother board (beware of a thick piece (maybe transformer)) that can avoid placing your switch. My switch come from www.conrad.fr with ref n° 705325 (perfect fit at the chosen place)
  • Solder two thin wire ~ 4cm very close to the switch body, routing them so they don't touch the motherboard.
Hier Übersetzung einfügen
