Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 1 übersetzen
Turn the device upside-down and insert a pry tool between the two case pieces.
Work the pry tool around the edge of the case, releasing the 18 clips. Don't insert your tool too far, or you may damage components near the edges of the device. The clips are all in the outer edge of the backplate anyway. Note that the clip above the power switch is bigger and stronger than the rest.
Pull the rear cover off. The remaining two clips near the center of the back are surprisingly strong.
