Zum Hauptinhalt wechseln
iPod Nano 5th Generation Logic Board Assembly Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
iPod Nano 5th Generation Logic Board Assembly Replacement: Schritt 0, Bild 1 von 3 iPod Nano 5th Generation Logic Board Assembly Replacement: Schritt 0, Bild 2 von 3 iPod Nano 5th Generation Logic Board Assembly Replacement: Schritt 0, Bild 3 von 3
  • Use a heat gun to soften the adhesive underneath the camera/microphone cover.
  • Pry the camera/microphone cover off the case with a metal spudger and remove it.
  • It is extremely difficult, if not impossible, to avoid damaging the iPod case near the camera. While this will not affect the iPod's functionality, it will hurt its cosmetic appearance.
  • You can try this alternative method for removing the cover:
  • Use a hot glue gun to apply a bead of glue across the cover.
  • Move the nozzle in the glue for 20 seconds to heat the lens adhesive holding the lens in place.
  • Press a spudger into the hot glue and hold it in place until the glue cools and hardens.
  • Pull on the spudger with firm steady force, while using a fingernail to pry on the cover edge.
Hier Übersetzung einfügen
