Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 6
Orient the console so that the left case is facing toward you and the faceplate is facing toward the right. Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
  • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
  • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
  • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
  • You will hear a "pop" signifying that the clip cleared its catch.
Hier Übersetzung einfügen
