Zum Hauptinhalt wechseln
iPod Touch 4th Generation Front Panel Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 7
iPod Touch 4th Generation Front Panel Replacement: Schritt 0, Bild 1 von 3 iPod Touch 4th Generation Front Panel Replacement: Schritt 0, Bild 2 von 3 iPod Touch 4th Generation Front Panel Replacement: Schritt 0, Bild 3 von 3
  • Insert the edge of an opening tool under the steel mid plate near the bottom left corner of the Touch.
  • Slowly pry upward to separate the plate from the adhesive securing it to the plastic inner case.
  • If the plate is still attached to the logic board, re-warm the area to loosen the adhesive, then slowly separate the plate from the logic board using the opening tool.
  • There is a thin, fragile ribbon cable underneath the plate. As you pry the plate up, be very careful not to rip the cable.
  • This cable may stick to the plate and will tear very easily if you're not careful. Work slowly and be careful not to strain the cable.
Hier Übersetzung einfügen
