Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 2 übersetzen
Schritt 2
Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
- | [* icon_caution] Throughout the following procedure, you'll be sliding thin plastic |
+ | [* icon_caution] Throughout the following procedure, you'll be sliding thin [product|IF145-101|plastic card]s between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals. |
[* black] Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker. | |
[* icon_note] If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften. |
