Zum Hauptinhalt wechseln
iPod Touch 4th Generation Upper Logic Board Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 3 übersetzen
Schritt 3
iPod Touch 4th Generation Upper Logic Board Replacement: Schritt 0, Bild 1 von 2 iPod Touch 4th Generation Upper Logic Board Replacement: Schritt 0, Bild 2 von 2
  • Use an iPod opening tool to slightly lift the edge of the logic board next to the battery enough to grab it with your other hand.
  • Do not excessively bend the logic board, as it is very thin and fragile.
  • Be very careful not to lift too much as the volume control ribbon cable is still connected and will tear very easily.
  • While gently lifting the logic board with one hand, use an iPod opening tool to lift the logic board near the copper tape at the logic board's top edge.
  • The logic board will be lifted adequately when the last display assembly connector has cleared the top edge of the rear case.
Hier Übersetzung einfügen
