Zum Hauptinhalt wechseln
How to repair a frayed Apple AC Adapter Wire
Englisch
Koreanisch
Schritt 2
How to repair a frayed Apple AC Adapter Wire: Schritt 0, Bild 1 von 2 How to repair a frayed Apple AC Adapter Wire: Schritt 0, Bild 2 von 2
  • Measure the approximate length of heat shrink needed to throughly cover all nearby damage with a single piece of heat shrink.
  • The length of the heat shrink should be longer than the actual length of the damaged or exposed wire.
  • Use 3/8"(10mm) diameter heat shrink. This size diameter is large enough to slide over the charging interface and small enough to secure itself on the wire when heated.
  • Cut the heat shrink to the appropriate length using scissors.
Hier Übersetzung einfügen
