Zum Hauptinhalt wechseln
2012-2015 Honda Civic Key Battery Replacement
Englisch
Koreanisch
Schritt 3
2012-2015 Honda Civic Key Battery Replacement, Replace the battery: Schritt 0, Bild 1 von 1
Replace the battery
  • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
  • Remove the battery.
  • Your key may contain either a CR1616 or CR1620 battery. In some cases, either type will work, but for the best results, replace it with the same kind of battery that originally came with your key.
  • Install your matching new battery in the same orientation as the original.
Hier Übersetzung einfügen
