Zum Hauptinhalt wechseln
HP Envy 17-3070NR Fan Assembly Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
HP Envy 17-3070NR Fan Assembly Replacement: Schritt 0, Bild 1 von 3 HP Envy 17-3070NR Fan Assembly Replacement: Schritt 0, Bild 2 von 3 HP Envy 17-3070NR Fan Assembly Replacement: Schritt 0, Bild 3 von 3
  • Remove the three 4.5mm Phillips screws on the fan assembly.
  • Loosen the seven captive Phillips screws in the ascending numerical order (1-7). Numbers are printed next to each screw on the housing.
  • Screws will not fully come off the assembly. You need to only loosen them.
  • Remove the fan assembly from the system board by lifting it straight up.
  • For reassembly, you will need to clean the old thermal paste off of areas highlighted in yellow as well as matching parts on the fan assembly. Following that, you would need to reapply thermal paste before putting back the fan assembly. Small amount of the size of the rice grain should be enough for each plate.
Hier Übersetzung einfügen
