Zum Hauptinhalt wechseln
Retina MacBook 2015 Opening Lower Case Assembly
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 5
Retina MacBook 2015 Opening Lower Case Assembly: Schritt 0, Bild 1 von 3 Retina MacBook 2015 Opening Lower Case Assembly: Schritt 0, Bild 2 von 3 Retina MacBook 2015 Opening Lower Case Assembly: Schritt 0, Bild 3 von 3
  • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
  • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
  • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
  • This step ensures the MacBook is fully powered down and safe to work on.
Hier Übersetzung einfügen
