Zum Hauptinhalt wechseln
HP Envy 14 Screen Replacement
Englisch
Koreanisch
Schritt 6
HP Envy 14 Screen Replacement: Schritt 0, Bild 1 von 3 HP Envy 14 Screen Replacement: Schritt 0, Bild 2 von 3 HP Envy 14 Screen Replacement: Schritt 0, Bild 3 von 3
  • Use the 3mm Phillips Screwdriver to remove the 4 black screws found on the metal tabs above and below the corners of the screen.
  • Don't get confused with the other black screws on the top corners. The ones you want to remove are located closer to the middle of the screen.
  • Lean the laptop cover back and unscrew the bottom 2 screws first so that the screen doesn't fall over as you are removing the screws.
  • Put these 4 screws in a separate container so they do not get mixed up with the 2 screws you already removed.
Hier Übersetzung einfügen
