Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 23 Anleitungen, die diese beinhalten.
Schritt 1 übersetzen
Schritt 1
Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
- | [* red] Remove the nine 6.3 mm black Phillips screws from the lower case. |
- | [* icon_caution] These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them. |
- | [* orange] Remove the 2.4 mm silver Phillips screw above the game cartridge slot. |
+ | [* red] Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case. |
+ | [* icon_caution] JIS (Japanese Industrial Standards) screws are ***not*** the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You ''can'' use a PHILLIPS #00 with a lot of downwards force but be warned this ***will*** deform the screw head and you risk stripping it. |
+ | [* icon_note] iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this. |
+ | [* orange] Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot. |
