Zum Hauptinhalt wechseln
Bootloader, Wiederherstellung und die Freude am Entsperren mittels eines Android-Telefons
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Bootloader, Recovery, and the joy of unlocking, Reboot to the bootloader, or reboot in Safe Mode: Schritt 0, Bild 1 von 3 Bootloader, Recovery, and the joy of unlocking, Reboot to the bootloader, or reboot in Safe Mode: Schritt 0, Bild 2 von 3 Bootloader, Recovery, and the joy of unlocking, Reboot to the bootloader, or reboot in Safe Mode: Schritt 0, Bild 3 von 3
  • All steps in this guide will vary from one phone model to another. Read your device's documentation to determine the specific steps required.
  • To power down most phones, hold down the power button until a prompt appears. Tap on the pop-up message. Some devices may have a "Power off" command in the software settings.
  • If your phone is crashing or locking up after boot, try rebooting into safe mode. In the previous step, tap and hold on "Power off" until the prompt changes to "Reboot to safe mode." Tap OK.
  • Most third party apps will not run under safe mode. If the phone runs okay, then reboot normally and start uninstalling apps until you determine which one was the culprit.
  • Some apps' settings will be lost or reset after using safe mode. You may have to set them up again.
  • With the phone in an off state, hold down buttons in a combination to enter the bootloader. Google Nexus models have specific combinations like holding Volume Down and Power simultaneously.
  • Your device's bootloader may look different from this Nexus 5 screen. That's okay. Note the essential information available to you here: phone model, product variant, serial/IMEI number, SIM and bootloader locked state.
Alle Schritte in dieser Anleitung variieren von einem Telefonmodell zum anderen. Lies die Dokumentation Deines Geräts, um die spezifischen erforderlichen Schritte zu ermitteln.
Um die meisten Telefone auszuschalten, halte die Einschalttaste gedrückt, bis eine Aufforderung erscheint. Tippe auf die Pop-up-Meldung. Bei einigen Geräten gibt es in den Software-Einstellungen den Befehl "Ausschalten".
Wenn Dein Telefon nach dem Hochfahren abstürzt oder sich sperrt, versuche, im abgesicherten Modus neu zu starten. Tippe im vorherigen Schritt auf "Ausschalten" und halte die Taste gedrückt, bis sich die Aufforderung in "Neustart im abgesicherten Modus" ändert. Tippe auf "OK".
Die meisten Apps von Drittanbietern werden im abgesicherten Modus nicht ausgeführt. Wenn das Telefon einwandfrei läuft, starte es normal neu und beginne mit der Deinstallation von Apps, bis Du herausgefunden hast, welche der Apps der Übeltäter war.
Die Einstellungen einiger Apps gehen nach der Verwendung des abgesicherten Modus verloren oder werden zurückgesetzt. Möglicherweise musst Du sie neu einrichten.
Halte im ausgeschalteten Zustand des Telefons die Tasten in einer Kombination gedrückt, um den Bootloader zu öffnen. Bei den Google Nexus-Modellen gibt es bestimmte Kombinationen, wie z. B. das gleichzeitige Gedrückthalten von Lautstärke und Power.
Der Bootloader Deines Geräts sieht möglicherweise anders aus als dieser Bildschirm des Nexus 5. Das ist in Ordnung. Beachte die wesentlichen Informationen, die Dir hier zur Verfügung stehen: Telefonmodell, Produktvariante, Serien-/IMEI-Nummer, SIM- und Bootloader-Sperrzustand.
