Zum Hauptinhalt wechseln
Bootloader, Wiederherstellung und die Freude am Entsperren mittels eines Android-Telefons
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Bootloader, Recovery, and the joy of unlocking, Recovery is your friend: Schritt 0, Bild 1 von 1
  • From your bootloader screen, toggling the volume buttons will offer functions like Start, Power Down, Restart Bootloader, and usually … Recovery. Pressing the Power button generally executes the displayed function.
  • The recovery partition is a rudimentary mini operating mode which allows loading updates, wiping the cache partition, and performing a factory reset to a phone that cannot boot properly (e.g. in an endless bootloop, never reaching an unlock screen). It's not called recovery for no reason -- it's an essential tool for restoring a broken phone.
  • Some phones are supported by third party recovery images, like ClockworkMod, with advance features including selective backup and restore, mounting partitions usually only accessible after the Android OS is running, and installing a root service.
  • Similar to Unix' superuser command, root allows the user to perform system-level actions. Rooting is a powerful tool that enables some features and access to the operating system while it is running.
  • Rooting suppresses built-in security protections of the operating system, and should only be done if you have full understanding of the risks. You should never grant an installed application root access, or permission to install a root service, without knowing exactly what it needs it for. 99.9% of apps will never need root access.
Von Deinen Bootloader-Bildschirm aus werden durch Umschalten der Lautstärketasten Funktionen wie Start, Power Down, Restart Bootloader und normalerweise ... Recovery angeboten. Das Drücken der Power-Taste führt in der Regel die angezeigte Funktion aus.
Die Wiederherstellungspartition ist ein rudimentärer Mini-Betriebsmodus, der das Laden von Updates, das Löschen der Cache-Partition und das Durchführen eines Werksresets bei einem Telefon ermöglicht, das nicht richtig booten kann (z. B. in einer endlosen Bootschleife, die nie einen Entsperrbildschirm erreicht).
Es heißt nicht ohne Grund Wiederherstellung - es ist ein unverzichtbares Werkzeug zur Wiederherstellung eines kaputten Telefons.
Einige Telefone werden von Wiederherstellungs-Images von Drittanbietern unterstützt, wie z. B. ClockworkMod, mit fortschrittlichen Funktionen, wie z. B. selektives Sichern und Wiederherstellen, Mounten von Partitionen, die normalerweise nur zugänglich sind, wenn das Android-Betriebssystem läuft, und Installieren eines Root-Dienstes.
Ähnlich wie der Unix-Befehl superuser erlaubt root dem Benutzer, Aktionen auf Systemebene durchzuführen. Rooting ist ein mächtiges Werkzeug, das einige Funktionen und den Zugriff auf das Betriebssystem ermöglicht, während es läuft.
Rooting unterdrückt die eingebauten Sicherheitsvorkehrungen des Betriebssystems und sollte nur dann durchgeführt werden, wenn Du Dir über die Risiken im Klaren bist.
Du solltest niemals einer installierten Anwendung Root-Zugriff oder die Erlaubnis zur Installation eines Root-Dienstes gewähren, ohne genau zu wissen, wofür sie diesen benötigt. 99,9 % der Anwendungen werden niemals Root-Zugriff benötigen.
