Zum Hauptinhalt wechseln
HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive
Englisch
Koreanisch
Schritt 5
HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: Schritt 0, Bild 1 von 3 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: Schritt 0, Bild 2 von 3 HP Pavilion - 17 g173ca Disassembly to access RAM and Hard drive: Schritt 0, Bild 3 von 3
  • With the bottom cover removed the hard drive and RAM are easily accessible.
  • The hard drive is held in only by friction,
  • To remove the hard drive from its mount lift the drive a bit from the end near the data and power cables
  • Disconnect the power and data cables, the cable is a delicate ribbon cable so be gentle, don't pull it out or the way too far.
  • Lift the cable end a bit more and slide the drive towards the ram a bit to release the clips holding down the other end.
  • the mounting frame can just be pulled free from the drive, it is also only attached by friction.
Hier Übersetzung einfügen
