Zum Hauptinhalt wechseln
Dell Latitude E6410 Screen Assembly Replacement
Englisch
Deutsch
Schritt 4
Dell Latitude E6410 Screen Assembly Replacement: Schritt 0, Bild 1 von 3 Dell Latitude E6410 Screen Assembly Replacement: Schritt 0, Bild 2 von 3 Dell Latitude E6410 Screen Assembly Replacement: Schritt 0, Bild 3 von 3
  • Remove the two 5mm Phillip's screws in the bottom right and the top left corners of the back panel.
  • Remove the 3mm Phillip's screw that is near the bottom right corner.
  • Loosen the Phillip's screw that is near the center until the spring pops up, but do not remove it.
  • Detach the back case panel by sliding it away from the battery slot and lifting it out of place.
  • When reattaching the back panel slide it towards the location of the battery instead of away from it while also applying pressure downwards.
Hier Übersetzung einfügen
