Zum Hauptinhalt wechseln
Nest Learning Thermostat 3rd Generation Stuck On
Englisch
Deutsch
Schritt 2
Nest Learning Thermostat 3rd Generation Stuck On, The Solution: Schritt 0, Bild 1 von 1
The Solution
  • The solution is to add a C wire, also called a common or ground wire.
  • The Nest Thermostat and Nest Base can use power between R and C and not affect the W (heating) wire.
  • Fortunately, in my installation, the wire used actually had three conductors. So I just had to strip and connect the third wire.
  • Also fortunately, the Caleffi ZSR-106 has a terminal for C, it just wasn't wired up. So it was a simple matter to strip and connect the third wire on this side too.
Hier Übersetzung einfügen
