Zum Hauptinhalt wechseln
India Mark II Traveling Valve Replacement
Englisch
Deutsch
Schritt 2
India Mark II Traveling Valve Replacement: Schritt 0, Bild 1 von 3 India Mark II Traveling Valve Replacement: Schritt 0, Bild 2 von 3 India Mark II Traveling Valve Replacement: Schritt 0, Bild 3 von 3
  • Use an open end wrench wrench, or other flat and hard tool, to brace against the two prongs on the bottom of the traveling valve.
  • Place an open end wrench on the top portion of the traveling valve. Hold this wrench steady while you turn the other wrench counterclockwise until the bottom unthreads.
  • Pull the pump assembly apart and inspect or replace parts as necessary.
  • Observe the directions and shapes of the traveling valve components in the third picture and be sure that the proper components are installed in your pump.
Hier Übersetzung einfügen
