Zum Hauptinhalt wechseln
Dell Inspiron 14z N114z Top Panel Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 5
Dell Inspiron 14z N114z Top Panel Replacement: Schritt 0, Bild 1 von 3 Dell Inspiron 14z N114z Top Panel Replacement: Schritt 0, Bild 2 von 3 Dell Inspiron 14z N114z Top Panel Replacement: Schritt 0, Bild 3 von 3
  • careful lifting up on the key board once free there is ribbon connected to the bottom.
  • Carefully flip laptop right side up and open to view the keyboard.
  • Using a plastic opening tool, pry up on the four tabs holding the keyboard in place. Be careful not to damage the keys on the top of the keyboard. You will know when it has been successfully pried open when you hear four clicks from the top of keyboard.
  • Gently lift the keyboard out from the rest of the laptop and immediately flip over without damaging the ribbon cable.
  • Carefully disconnect the ribbon cable by flipping up the tab holding the cable in place by using a plastic opening tool. Set keyboard and ribbon cable aside.
Hier Übersetzung einfügen
