Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 3 übersetzen
Schritt 3
Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
[* black] Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover. | |
- | [* icon_note] If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again. |
+ | [* icon_note] If the adhesive tabs break, try to use a thin flat plastic tool such as a [product|IF145-101|plastic card] to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again. |
