Zum Hauptinhalt wechseln
Fujifilm FinePix S4800 LCD Screen Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Fujifilm FinePix S4800 LCD Screen Replacement: Schritt 0, Bild 1 von 3 Fujifilm FinePix S4800 LCD Screen Replacement: Schritt 0, Bild 2 von 3 Fujifilm FinePix S4800 LCD Screen Replacement: Schritt 0, Bild 3 von 3
  • At this point, it is highly recommended that you wear an ESD wristband to prevent damage to the internal electronic components.
  • With respect to the camera that was disassembled for this guide, the LCD display easily fell out of its housing after the rear case was removed. If your screen fits more tightly, you can use a plastic removal tool to gently pry up one of the edges of the screen and that will release it from its mount.
  • Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
Hier Übersetzung einfügen
