Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die die grundständige Anleitung beinhaltet.
Schritt 3 übersetzen
Schritt 3
Remove the bottom screws
Once the battery and optical drive are removed, remove the 11 Phillips #0 screws that secure the palmrest.
This screw is hidden by a sticker. If lost/damaged, it is cosmetic.
Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
[title] Remove the bottom screws | |
- | [* red] Once the battery and optical drive are removed, remove the ***''11''*** screws that secure the palmrest. |
+ | [* icon_note] ***EET owners: Your kit has this bit. No purchase needed.*** |
+ | [* red] Once the battery and optical drive are removed, remove the ***''11 Phillips #0''*** screws that secure the palmrest. |
[* orange] This screw is hidden by a sticker. If lost/damaged, it is cosmetic. | |
[* yellow] ***''Not found on all models.''*** On some models, there are screws in this area. ***''If you see screws here, they must be removed.''*** |
