Zum Hauptinhalt wechseln
Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2 übersetzen
Schritt 2
Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement: Schritt 0, Bild 1 von 3 Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement: Schritt 0, Bild 2 von 3 Asus ROG Strix GL702VM-BHI7N09 Back Panel Replacement: Schritt 0, Bild 3 von 3
  • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
  • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
  • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
  • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
  • Once you have broken all the seals, carefully lift the panel off.
Hier Übersetzung einfügen
