Zum Hauptinhalt wechseln
iMac Intel 17" Logic Board Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6
iMac Intel 17" Logic Board Replacement: Schritt 0, Bild 1 von 2 iMac Intel 17" Logic Board Replacement: Schritt 0, Bild 2 von 2
  • Squeeze the two optical drive bracket ears together while pulling the drive up toward yourself.
  • It may be helpful to hold the logic board down near the optical drive connector when pulling the drive toward yourself to avoid both components lifting together.
  • Pull the optical drive away from the side of the rear case and remove it from the iMac.
  • If your optical drive is particularly stubborn to remove, try the method used in the optical drive guide from the A1144 G5 iMac.
Hier Übersetzung einfügen
