Zum Hauptinhalt wechseln
iPhone 7 디스플레이 어셈블리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 21 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2
iPhone 7 Display Assembly Replacement: Schritt 0, Bild 1 von 3 iPhone 7 Display Assembly Replacement: Schritt 0, Bild 2 von 3 iPhone 7 Display Assembly Replacement: Schritt 0, Bild 3 von 3
  • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
  • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
전면 패널 센서 어셈블리 커넥터 위로 브래킷을 고정하는 1.3mm Phillips/십자 나사 두 개를 풀어주세요.
브래킷을 분리하세요.
-[* red] Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
-[* black] Remove the bracket.
+[* red] Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
+ [* icon_note] Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
