Zum Hauptinhalt wechseln
MacBook Pro 17" Unibody Front Display Glass Replacement
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 6
MacBook Pro 17" Unibody Front Display Glass Replacement: Schritt 0, Bild 1 von 3 MacBook Pro 17" Unibody Front Display Glass Replacement: Schritt 0, Bild 2 von 3 MacBook Pro 17" Unibody Front Display Glass Replacement: Schritt 0, Bild 3 von 3
  • With the panel sufficiently heated, fasten a heavy-duty suction cup near the lower right corner of the display glass.
  • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
  • Gently lift the corner of the display glass enough to insert a guitar pick between it and the display assembly.
  • Use the guitar pick to gently pry up the adhesive securing the front glass to the display.
  • Pry up the glass panel along the right edge of the display up to the halfway point.
  • Leave the guitar pick in place halfway up the right side of the display and remove the suction cup.
Hier Übersetzung einfügen
