Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 7
Use a heat gun to soften the adhesive under the display glass along the right and top edges of the display. Attach a suction cup to the upper right corner of the front glass panel. Pull up on the glass panel while you use a second guitar pick to separate it from the rest of the display assembly.
  • Use a heat gun to soften the adhesive under the display glass along the right and top edges of the display.
  • Attach a suction cup to the upper right corner of the front glass panel.
  • Pull up on the glass panel while you use a second guitar pick to separate it from the rest of the display assembly.
  • Continue working along the right edge of the front display glass until it is separated from the display.
Hier Übersetzung einfügen
