Zum Hauptinhalt wechseln
MacBook Pro 15" Retina Display Mid 2012 오른쪽 팬 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 41 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2
MacBook Pro 15" Retina Display Mid 2012 Right Fan Replacement: Schritt 0, Bild 1 von 2 MacBook Pro 15" Retina Display Mid 2012 Right Fan Replacement: Schritt 0, Bild 2 von 2
  • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
  • Pull the AirPort card parallel out of its connector on the logic board to remove it.
AirPort 카드의 측면을 잡고 얕은 각도(5~10˚)로 들어올려서 로직 보드에 부착된 약한 접착제를 분리하세요.
AirPort 카드를 로직 보드의 커넥터에서 평행하게 당겨서 분리하세요.
