Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 33 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board. On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal. Carefully lift the I/O board and remove it from the lower case.
  • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
  • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
  • Carefully lift the I/O board and remove it from the lower case.
Entferne die beiden 3,1 mm T5 Torx-Schrauben, mit denen das I/O Board am Logic Board befestigt ist.
Hebe das I/O Board vorsichtig an und entferne es aus dem unteren Gehäuse.
[* red] Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
+ [* orange] On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
[* black] Carefully lift the I/O board and remove it from the lower case.
